Saltar al contenido principal
HP Split x2 13-g210dx SD Port Replacement
Qué necesitas
  1. HP Split x2 13-g210dx SD Port Replacement, Back Panel: paso 1, imagen 1 de 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx SD Port Replacement, Battery: paso 2, imagen 1 de 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx SD Port Replacement: paso 3, imagen 1 de 2 HP Split x2 13-g210dx SD Port Replacement: paso 3, imagen 2 de 2
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx SD Port Replacement: paso 4, imagen 1 de 2 HP Split x2 13-g210dx SD Port Replacement: paso 4, imagen 2 de 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx SD Port Replacement, SD Port: paso 5, imagen 1 de 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx SD Port Replacement: paso 6, imagen 1 de 2 HP Split x2 13-g210dx SD Port Replacement: paso 6, imagen 2 de 2
    • Remove the yellow ribbon labeled "SD" in the left corner of the SD port board using tweezers or a sturdy plastic opening tool.
  7. HP Split x2 13-g210dx SD Port Replacement: paso 7, imagen 1 de 1
    • Lift the SD port away from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 210
