Saltar al contenido principal
HP Split x2 13-g210dx Back Panel Replacement
Qué necesitas
  1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
Conclusión
Una persona más ha completado esta guía.
Un comentario
How do I put the felt cover back on?
Prince Phoenix - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 406
