Saltar al contenido principal
HP Split x2 13-g210dx Audio Ports Replacement
Qué necesitas
  1. HP Split x2 13-g210dx Audio Ports Replacement, Back Panel: paso 1, imagen 1 de 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Audio Ports Replacement, Battery: paso 2, imagen 1 de 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Audio Ports Replacement: paso 3, imagen 1 de 2 HP Split x2 13-g210dx Audio Ports Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Audio Ports Replacement: paso 4, imagen 1 de 2 HP Split x2 13-g210dx Audio Ports Replacement: paso 4, imagen 2 de 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Audio Ports Replacement, Audio Port: paso 5, imagen 1 de 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Audio Ports Replacement: paso 6, imagen 1 de 3 HP Split x2 13-g210dx Audio Ports Replacement: paso 6, imagen 2 de 3 HP Split x2 13-g210dx Audio Ports Replacement: paso 6, imagen 3 de 3
    Comprar
    • Remove the two purple ribbons labeled "Audio" at the top of the audio port board using tweezers or a sturdy plastic opening tool.
  7. HP Split x2 13-g210dx Audio Ports Replacement: paso 7, imagen 1 de 2 HP Split x2 13-g210dx Audio Ports Replacement: paso 7, imagen 2 de 2
    • Remove the white clip at the top right corner of the audio port board using tweezers.
  8. HP Split x2 13-g210dx Audio Ports Replacement: paso 8, imagen 1 de 1
    • Lift the Audio port away from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 239
