Introducción
If your laptop is not working, the motherboard may be to blame. The process of replacing the motherboard may also fix screen, battery, booting, and charging issues. This guide will show you how to replace the motherboard. Please note that this guide is specific to the HP Spectre x360 15-bl012dx.
Please visit our Troubleshooting Page before beginning disassembly.
Please make sure the laptop is turned off and disconnected from the charging adapter before you begin to this repair.
Qué necesitas
Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
Next, remove the four visible Torx T5 3 mm on the sides.
Using minimal force, lift the locking bars on the USB board ZIF connector using a plastic opening tool or fingernail and pull out the ribbon cable.
Clean the old thermal paste off of the heat sink, cpu, and gpu using isopropyl alcohol and a paper towel. The higher the percentage of the alcohol, the better. I used 91%.
Remember to apply thermal paste before installing the new motherboard with fresh thermal paste! A pea sized amount is plenty.
Una persona más ha completado esta guía.
