Saltar al contenido principal
HP Spectre x360 13-ac023dx WiFi Card Replacement
Qué necesitas
  1. HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: paso 1, imagen 1 de 2 HP Spectre x360 13-ac023dx WiFi Card Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx WiFi Card Replacement: paso 2, imagen 1 de 3 HP Spectre x360 13-ac023dx WiFi Card Replacement: paso 2, imagen 2 de 3 HP Spectre x360 13-ac023dx WiFi Card Replacement: paso 2, imagen 3 de 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx WiFi Card Replacement: paso 3, imagen 1 de 2 HP Spectre x360 13-ac023dx WiFi Card Replacement: paso 3, imagen 2 de 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx WiFi Card Replacement, WiFi Card: paso 4, imagen 1 de 1
    • Locate the WiFi card.
  5. HP Spectre x360 13-ac023dx WiFi Card Replacement: paso 5, imagen 1 de 1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  6. HP Spectre x360 13-ac023dx WiFi Card Replacement: paso 6, imagen 1 de 2 HP Spectre x360 13-ac023dx WiFi Card Replacement: paso 6, imagen 2 de 2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
Conclusión
Jonathan
Miembro Desde 10/21/19
486 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 1,842
