Saltar al contenido principal
HP Spectre x360 13-ac023dx Motherboard Replacement
Qué necesitas
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: paso 1, imagen 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 2, imagen 1 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 2, imagen 2 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 3, imagen 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: paso 4, imagen 1 de 1
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 5, imagen 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 5, imagen 2 de 2
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: paso 7, imagen 1 de 1
    • Locate the WiFi card.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 8, imagen 1 de 1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 9, imagen 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 9, imagen 2 de 2
    • Once the screw is removed, raise the WiFi card and slide it out from the motherboard.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Ensure that all other components which were previously removed are not longer attached.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 11, imagen 1 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 11, imagen 2 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 11, imagen 3 de 3
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 12, imagen 1 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 12, imagen 2 de 3 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 12, imagen 3 de 3
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: paso 13, imagen 1 de 2 HP Spectre x360 13-ac023dx Motherboard Replacement: paso 13, imagen 2 de 2
    • Carefully lift and remove the motherboard.
Conclusión
Jonathan
Miembro Desde 10/21/19
486 Reputación
4 Guías creadas
Equipo
Un comentario
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 45
Todo El Tiempo: 3,463
