Saltar al contenido principal
HP Spectre x360 13-4103dx Back Panel Replacement
Qué necesitas
  1. HP Spectre x360 13-4103dx Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn off your laptop before you start.
    • Flip your laptop so the bottom is facing upwards.
  2. HP Spectre x360 13-4103dx Back Panel Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #0 to remove the screws that hold the back panel down.
  3. HP Spectre x360 13-4103dx Back Panel Replacement: paso 3, imagen 1 de 1
    • Use an opening tool to remove the back panel.
    • Be careful when applying force to the panel so the components and the panel are not damaged.
    • Try to start at a corner or a place with the most room to slide under the panel.
Conclusión
Andrew Medeiros
Miembro Desde 10/25/21
511 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 3-6, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 3-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G6
Miembros de 3
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 745
