Saltar al contenido principal
HP Spectre 13-4002dx Vent Fan Replacement
Qué necesitas
  1. HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: paso 1, imagen 1 de 2 HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Vent Fan Replacement: paso 2, imagen 1 de 2 HP Spectre 13-4002dx Vent Fan Replacement: paso 2, imagen 2 de 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: paso 3, imagen 1 de 3 HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: paso 3, imagen 2 de 3 HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: paso 3, imagen 3 de 3
    • Remove the strip of black electrical tape.
    • Pull the tape away from the vent fan.
    • Pull gently, as the tape is easy to rip.
  4. HP Spectre 13-4002dx Vent Fan Replacement: paso 4, imagen 1 de 2 HP Spectre 13-4002dx Vent Fan Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard.
  5. HP Spectre 13-4002dx Vent Fan Replacement: paso 5, imagen 1 de 3 HP Spectre 13-4002dx Vent Fan Replacement: paso 5, imagen 2 de 3 HP Spectre 13-4002dx Vent Fan Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, disconnect the wire connection between the laptop and the vent fan.
  6. HP Spectre 13-4002dx Vent Fan Replacement: paso 6, imagen 1 de 1
    • Remove the vent fan.
Conclusión
Un comentario
Any idea what model# the fan is?
ayekay - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 286
