Saltar al contenido principal
HP Spectre 13-4002dx Touchpad Replacement
Qué necesitas
  1. HP Spectre 13-4002dx Touchpad Replacement, Bottom Case: paso 1, imagen 1 de 2 HP Spectre 13-4002dx Touchpad Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Touchpad Replacement: paso 2, imagen 1 de 2 HP Spectre 13-4002dx Touchpad Replacement: paso 2, imagen 2 de 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Touchpad Replacement, Battery: paso 3, imagen 1 de 3 HP Spectre 13-4002dx Touchpad Replacement, Battery: paso 3, imagen 2 de 3 HP Spectre 13-4002dx Touchpad Replacement, Battery: paso 3, imagen 3 de 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Touchpad Replacement: paso 4, imagen 1 de 3 HP Spectre 13-4002dx Touchpad Replacement: paso 4, imagen 2 de 3 HP Spectre 13-4002dx Touchpad Replacement: paso 4, imagen 3 de 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Touchpad Replacement: paso 5, imagen 1 de 2 HP Spectre 13-4002dx Touchpad Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Touchpad Replacement: paso 6, imagen 1 de 3 HP Spectre 13-4002dx Touchpad Replacement: paso 6, imagen 2 de 3 HP Spectre 13-4002dx Touchpad Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Touchpad Replacement: paso 7, imagen 1 de 1
    • Carefully remove the battery.
  8. HP Spectre 13-4002dx Touchpad Replacement, Touchpad: paso 8, imagen 1 de 3 HP Spectre 13-4002dx Touchpad Replacement, Touchpad: paso 8, imagen 2 de 3 HP Spectre 13-4002dx Touchpad Replacement, Touchpad: paso 8, imagen 3 de 3
    • The touchpad is boxed in red.
    • Remove the five 20 mm Phillips #0 screws.
  9. HP Spectre 13-4002dx Touchpad Replacement: paso 9, imagen 1 de 1
    • Remove the connector outlined in red.
  10. HP Spectre 13-4002dx Touchpad Replacement: paso 10, imagen 1 de 3 HP Spectre 13-4002dx Touchpad Replacement: paso 10, imagen 2 de 3 HP Spectre 13-4002dx Touchpad Replacement: paso 10, imagen 3 de 3
    • To release the ribbon cable, flip up the white tab on the connector 90 degrees.
    • Pull the ribbon cable out of the connector.
  11. HP Spectre 13-4002dx Touchpad Replacement: paso 11, imagen 1 de 1
    • Remove the touchpad.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 194
