Saltar al contenido principal
HP Spectre 13-4002dx Heat Sink Replacement
Qué necesitas
  1. HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: paso 1, imagen 1 de 2 HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Heat Sink Replacement: paso 2, imagen 1 de 2 HP Spectre 13-4002dx Heat Sink Replacement: paso 2, imagen 2 de 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: paso 3, imagen 1 de 3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: paso 3, imagen 2 de 3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: paso 3, imagen 3 de 3
    • Remove the tape outlined in red.
    • The tape can tear easily.
  4. HP Spectre 13-4002dx Heat Sink Replacement: paso 4, imagen 1 de 2 HP Spectre 13-4002dx Heat Sink Replacement: paso 4, imagen 2 de 2
    • Remove the four 3 mm screws using a Phillips #0 screwdriver.
  5. HP Spectre 13-4002dx Heat Sink Replacement: paso 5, imagen 1 de 1
    • Remove the heat sink from the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 281
