Saltar al contenido principal
HP Spectre 13-3010dx Battery Replacement
Qué necesitas
  1. HP Spectre 13-3010dx Battery Replacement, Removal of the Back Case: paso 1, imagen 1 de 2 HP Spectre 13-3010dx Battery Replacement, Removal of the Back Case: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Put on Anti Static Wrist Strap.
    • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
    • Flip Computer Upside down.
    • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
  2. HP Spectre 13-3010dx Battery Replacement: paso 2, imagen 1 de 2 HP Spectre 13-3010dx Battery Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to lift the back case off.
    • Use the plastic opening tools first; metal spudgers can damage your device.
  3. HP Spectre 13-3010dx Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
  4. HP Spectre 13-3010dx Battery Replacement: paso 4, imagen 1 de 1
    • Gently unplug from CONO851 plug, using the plastic opening tool.
  5. HP Spectre 13-3010dx Battery Replacement: paso 5, imagen 1 de 2 HP Spectre 13-3010dx Battery Replacement: paso 5, imagen 2 de 2
    • Gently lift up the battery and remove using the plastic opening tools.
Conclusión
11 personas más completaron esta guía.
4 comentarios
Good Job presenting the steps. I need to find a battery for my hp 13-3010dx ultrabook. Any ideas where one can be purchased.
Dawson Wilke - Contestar
Hi Dawson Wilke, the battery seems has two kinds of interface, I suggest you take out your old battery check the battery model and product parameter, such as voltage and current as well as the interface, then search the right battery from online store. If you confuse on it, I am here willing to help you.
julie -
Hi i did this found a battery online and did an installation of the replacement. Unfortunately it is not an original hp battery as none are available. However the issue I am having is that the new battery is not being detected. Any recommendations?
Leah Cleghorn - Contestar
Cosmas Dorah - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 18,952
