Saltar al contenido principal
HP Spectre x360 13-ac023dx Battery Replacement
Qué necesitas
  1. HP Spectre  x360 13-ac023dx Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Spectre  x360 13-ac023dx Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre  x360 13-ac023dx Battery Replacement: paso 2, imagen 1 de 3 HP Spectre  x360 13-ac023dx Battery Replacement: paso 2, imagen 2 de 3 HP Spectre  x360 13-ac023dx Battery Replacement: paso 2, imagen 3 de 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre  x360 13-ac023dx Battery Replacement: paso 3, imagen 1 de 2 HP Spectre  x360 13-ac023dx Battery Replacement: paso 3, imagen 2 de 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
Conclusión
5 personas más completaron esta guía.
Dylan Beery
Miembro Desde 10/21/19
290 Reputación
1 Guía escrita
Equipo
4 comentarios
The overall procedure is ok, however as others commented instructions on how to remove the feet would be helpful. I tried a heat gun to help loosen the glue, however that just melted the feat. Overall go the job done, but 2 out of the 4 feet were destroyed in the process.
Also in my case there were no screws under the top or bottom feet, so I could have probably removed the cover without removing the feet.
Joseph Ficara - Contestar
I think HP quietly refreshed the internals of this laptop or something, because despite appearing externally identical to the laptop shown in the pictures, mine has a smaller main board and differently sized battery. so you should open yours up and check before ordering the battery. mine has the PK03XL. this is double annoying because I was repairing this one for a friend, and she's the one who ordered the battery.
csd - Contestar
just finished my repair of my w-013 version. good to know that the top two feet have screws underneath them - small risk of denting the bottom cover if you're not gentle. also, the cable is slightly too long to fit neatly in the battery receptacle - it required some jamming that i'll probably be concerned about for a while.
pkim - Contestar
This guide was helpful but my bottom two feet didn't have screws. I used a T4 instead of T5 and for the Phillips a T0 and a T1.
The battery had two metal stickers on it under the bottom feet so I put them on the replacement battery in the same place.
My model is 13-ac033dx
Oliver Hansen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 54
Ultimos 30 días: 197
Todo El Tiempo: 9,319
