Saltar al contenido principal
HP Slate 7 Plus 4200US Tablet Cover Replacement
Qué necesitas
  1. HP Slate 7 Plus 4200US Tablet Cover Replacement, Tablet Cover: paso 1, imagen 1 de 1
    • Turn off the tablet and disconnect the power and all external devices from the tablet.
    • Position the tablet with the display panel down and the right side toward you.
    • Carefully insert a plastic opening tool between the tablet cover and display panel assembly, separating the two components. The first insertion point should be between the power button and the volume buttons.
  2. HP Slate 7 Plus 4200US Tablet Cover Replacement: paso 2, imagen 1 de 2 HP Slate 7 Plus 4200US Tablet Cover Replacement: paso 2, imagen 2 de 2
    • Slide the tool around the perimeter of the tablet until the edge of the cover is completely separated from the display panel assembly.
  3. HP Slate 7 Plus 4200US Tablet Cover Replacement: paso 3, imagen 1 de 3 HP Slate 7 Plus 4200US Tablet Cover Replacement: paso 3, imagen 2 de 3 HP Slate 7 Plus 4200US Tablet Cover Replacement: paso 3, imagen 3 de 3
    • Pry open the back cover to take it off.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 3-1, Sullivan Fall 2016 Miembro de USF Tampa, Team 3-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G1
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 277
