Introducción
If your computer frequently gets very hot and overheats you may need to replace the fan. Before performing any work remember to completely turn off your computer and disconnect it from any power source.
Qué necesitas
Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
Remove both 3/8" screws using the T15 Torx Screwdriver from the metal plate, and slide the plate to the left.
Casi Terminas!
Conclusión
