Saltar al contenido principal
HP ProDesk 400 G5 Mini RAM Replacement / Upgrade
Qué necesitas
  1. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: paso 1, imagen 1 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: paso 1, imagen 2 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade, RAM: paso 1, imagen 3 de 3
    • Turn the device around the back is facing you.
    • See the large screw in the center back of the PC.
  2. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 2, imagen 1 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 2, imagen 2 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 2, imagen 3 de 3
    • Remove the thumbscrew holding the back panel onto the PC.
  3. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 3, imagen 1 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 3, imagen 2 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 3, imagen 3 de 3
    • Slide the top panel off away from the back of the device.
    • Then, carefully lift it upwards to remove it.
  4. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 4, imagen 1 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 4, imagen 2 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 4, imagen 3 de 3
    • Gently lift the main fan to expose the RAM modules.
  5. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 5, imagen 1 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 5, imagen 2 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 5, imagen 3 de 3
    • Using your fingers, pull the metal arms (located on both sides of the RAM module) slightly away from it, to release it from the slot.
    • The RAM will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
  6. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 6, imagen 1 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 6, imagen 2 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 6, imagen 3 de 3
    • To insert a new RAM stick, line up the indent on the RAM with the indent on the slot, then slide it in.
  7. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 7, imagen 1 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 7, imagen 2 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 7, imagen 3 de 3
    • Push the RAM stick down flat once it's securely attached to the socket.
    • You should hear a tactile click which indicates it was installed correctly.
    • Make sure the arms on both sides go back to their locked position.
  8. HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 8, imagen 1 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 8, imagen 2 de 3 HP ProDesk 400 G5 Mini RAM Replacement / Upgrade: paso 8, imagen 3 de 3
    • After RAM installation, place the fan back on top of the RAM and replace the panel by sliding it into place and tightening it with the thumbscrew.
Conclusión
2 personas más completaron esta guía.
Sam Manshouri
Miembro Desde 02/01/23
187 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 47
Ultimos 30 días: 197
Todo El Tiempo: 2,015
