Saltar al contenido principal
HP ProBook x360 11 G5 EE Wireless Card Replacement
Qué necesitas
  1. HP ProBook x360 11 G5 EE Wireless Card Replacement, Keyboard Assembly: paso 1, imagen 1 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement, Keyboard Assembly: paso 1, imagen 2 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement, Keyboard Assembly: paso 1, imagen 3 de 3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 2, imagen 1 de 1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 3, imagen 1 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 3, imagen 2 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 3, imagen 3 de 3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 4, imagen 1 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 4, imagen 2 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 4, imagen 3 de 3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 5, imagen 1 de 2 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 5, imagen 2 de 2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Wireless Card Replacement, Battery: paso 6, imagen 1 de 2 HP ProBook x360 11 G5 EE Wireless Card Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 7, imagen 1 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 7, imagen 2 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 7, imagen 3 de 3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Wireless Card Replacement, Wireless Card: paso 8, imagen 1 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement, Wireless Card: paso 8, imagen 2 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement, Wireless Card: paso 8, imagen 3 de 3
    • Disconnect the ribbon wire from the motherboard by lifting the small flap that holds it in place.
  9. HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 9, imagen 1 de 2 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 9, imagen 2 de 2
    • Remove both antenna cables that are attached to the wireless card.
  10. HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 10, imagen 1 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 10, imagen 2 de 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: paso 10, imagen 3 de 3
    • Remove the 3 mm screw that secures the wireless card using a JIS #0 screwdriver.
    • Slide the wireless card out of the slot gently.
    • Make sure not to pull it directly up as it can break.
Conclusión
Una persona más ha completado esta guía.
Michelle Pina
Miembro Desde 10/26/21
506 Reputación
4 Guías creadas
Equipo
Gateway, Team 1-4, Pee Fall 2021 Miembro de Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 574
