Saltar al contenido principal
HP ProBook x360 11 G5 EE Charging Port Replacement
Qué necesitas
  1. HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: paso 1, imagen 1 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: paso 1, imagen 2 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement, Keyboard Assembly: paso 1, imagen 3 de 3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Charging Port Replacement: paso 2, imagen 1 de 1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Charging Port Replacement: paso 3, imagen 1 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 3, imagen 2 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 3, imagen 3 de 3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Charging Port Replacement: paso 4, imagen 1 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 4, imagen 2 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 4, imagen 3 de 3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Charging Port Replacement: paso 5, imagen 1 de 2 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 5, imagen 2 de 2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: paso 6, imagen 1 de 2 HP ProBook x360 11 G5 EE Charging Port Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Charging Port Replacement: paso 7, imagen 1 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 7, imagen 2 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 7, imagen 3 de 3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: paso 8, imagen 1 de 2 HP ProBook x360 11 G5 EE Charging Port Replacement, Charging Port: paso 8, imagen 2 de 2
    • Remove the single 3 mm screw from the charging port using a T5 Torx screwdriver.
  9. HP ProBook x360 11 G5 EE Charging Port Replacement: paso 9, imagen 1 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 9, imagen 2 de 3 HP ProBook x360 11 G5 EE Charging Port Replacement: paso 9, imagen 3 de 3
    • Disconnect the charging port wire from the motherboard.
    • Remove the charging port from your device.
Conclusión
Una persona más ha completado esta guía.
Michelle Pina
Miembro Desde 10/26/21
506 Reputación
4 Guías creadas
Equipo
Gateway, Team 1-4, Pee Fall 2021 Miembro de Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Miembros
5 Guías creadas
2 comentarios
Hi!! I have the same model of notebook with 64 giga emmc. Is it possible installing an ssd or an hdd?
Riccardo Insolera - Contestar
I followed each and every step, and realised a little too late that my laptop is a HP ProBook x360 11 G1 -and not a G5. The G1 requires the ability to de-solder the built in charging port.
On step 6, I noticed there were 6 screws holding the battery in, not 4.
Then on step 9, I noticed that the charging port is actually soldered to the motherboard and there is no visible cable attaching it to the board which can be unhooked.
Sam T - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 23
Todo El Tiempo: 1,161
