Introducción
The motherboard is one of the computer’s most important components. Any issues involving the motherboard can only be resolved by removing the component from the rest of the computer.
Qué necesitas
Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
Slide the two release latches that were mentioned in the battery removal process to release the service panel.
Using a Phillips #0 Screwdriver, remove the four Phillips 3 mm screws that secure the hard drive into the computer.
Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
Use the tweezers to remove the six rubber stops on the side edges of the laptop.
Using the Torx T8 screwdriver, remove the 13 Torx 6 millimeter screws on the bottom frame of the laptop.
Using the Phillips P0 screwdriver, remove the 2 Phillips 6 millimeter screws on the bottom frame of the laptop.
Remove the 2 Phillips 3 millimeter screws from the edge of the frame where the optical drive was previously located.
Remove the 5 Phillips 3 millimeter screws from the area where the battery was previously located.
6 personas más completaron esta guía.
