Saltar al contenido principal
HP ProBook 455 G1 DVD/CD Drive Replacement
Qué necesitas
  1. HP ProBook 455 G1 DVD/CD Drive  Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 DVD/CD Drive  Replacement: paso 2, imagen 1 de 1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 DVD/CD Drive  Replacement: paso 3, imagen 1 de 2 HP ProBook 455 G1 DVD/CD Drive  Replacement: paso 3, imagen 2 de 2
    • Tilt the battery upward.
    • Remove it from the laptop.
  4. HP ProBook 455 G1 DVD/CD Drive  Replacement, Service Panel: paso 4, imagen 1 de 1
    • Slide the two release latches that were mentioned in the battery removal process to release the service panel.
  5. HP ProBook 455 G1 DVD/CD Drive  Replacement: paso 5, imagen 1 de 2 HP ProBook 455 G1 DVD/CD Drive  Replacement: paso 5, imagen 2 de 2
    • Slide the service panel toward you using your thumbs.
    • Lift it to remove the panel and reveal inner components of the computer.
  6. HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: paso 6, imagen 1 de 2 HP ProBook 455 G1 DVD/CD Drive  Replacement, DVD/CD Drive: paso 6, imagen 2 de 2
    • Using a Phillips P0 Screwdriver, remove the 6 millimeter screw that secures the DVD/CD drive to the computer.
    • It will be located in the upper left section of the computer, housed in a small square hole in the computer frame.
    • The Phillips head screwdriver is the screwdriver with a "+" shaped tip. P0 refers to the name/size of this particular Phillips head screwdriver.
  7. HP ProBook 455 G1 DVD/CD Drive  Replacement: paso 7, imagen 1 de 1
    • Using the screwdriver, gently push the silver tab that the screw secured to the left to release the DVD/CD drive from the computer.
  8. HP ProBook 455 G1 DVD/CD Drive  Replacement: paso 8, imagen 1 de 1
    • The DVD/CD drive will be extended from the side of the laptop. Slowly remove it from the computer.
Conclusión
Jennifer Sexton
Miembro Desde 03/18/18
649 Reputación
4 Guías creadas
Equipo
Baylor, Team S5-G1, Williams Spring 2018 Miembro de Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 26
Todo El Tiempo: 939
