Saltar al contenido principal
HP ProBook 455 G1 Battery Replacement
  1. HP ProBook 455 G1 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer upside down on a flat side, so that you are seeing the underside of the laptop.
    • Before removing the battery, make sure that the computer is turned off and that the power cord is not plugged into the computer.
  2. HP ProBook 455 G1 Battery Replacement: paso 2, imagen 1 de 1
    • Slide the two battery release latches towards the center of the laptop to release the battery.
  3. HP ProBook 455 G1 Battery Replacement: paso 3, imagen 1 de 2 HP ProBook 455 G1 Battery Replacement: paso 3, imagen 2 de 2
    • Tilt the battery upward.
    • Remove it from the laptop.
Conclusión
Jennifer Sexton
Miembro Desde 03/18/18
649 Reputación
4 Guías creadas
Equipo
Baylor, Team S5-G1, Williams Spring 2018 Miembro de Baylor, Team S5-G1, Williams Spring 2018
BU-WILLIAMS-S18S5G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 975
