Saltar al contenido principal
HP ProBook 4540s WLAN Module Replacement
Qué necesitas
  1. HP ProBook 4540s WLAN Module Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s WLAN Module Replacement, Bottom Door: paso 2, imagen 1 de 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s WLAN Module Replacement, WLAN Module: paso 3, imagen 1 de 2 HP ProBook 4540s WLAN Module Replacement, WLAN Module: paso 3, imagen 2 de 2
    • Disconnect the antenna cables from their terminals in the WLAN module.
    • One cable is attached to the Auxiliary ("Aux") terminal, represented with a blue wire. The other cable is connected to the Main terminal which is usually represented with a red wire. These wires can be seen in little windows beside the component.
  4. HP ProBook 4540s WLAN Module Replacement: paso 4, imagen 1 de 2 HP ProBook 4540s WLAN Module Replacement: paso 4, imagen 2 de 2
    • Unscrew two 3.0 mm Phillips PM2.0x3.0 screw securing the module to the computer.
    • The edge of the module that is opposite of the slot is risen away from the computer.
    • Gently lift and remove the module.
Conclusión
2 personas más completaron esta guía.
Amber Schindler
Miembro Desde 10/26/16
1,027 Reputación
6 Guías creadas
Equipo
UW Tacoma, Team 1-5, Rose Fall 2016 Miembro de UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 25
Todo El Tiempo: 1,826
