Saltar al contenido principal
HP ProBook 4540s Optical Drive Replacement
Qué necesitas
  1. HP ProBook 4540s Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Optical Drive Replacement, Bottom Door: paso 2, imagen 1 de 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: paso 3, imagen 1 de 2 HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: paso 3, imagen 2 de 2
    • Remove one 6.0 mm Phillips PM2.5x6.0 screw that is securing the optical drive.
  4. HP ProBook 4540s Optical Drive Replacement: paso 4, imagen 1 de 2 HP ProBook 4540s Optical Drive Replacement: paso 4, imagen 2 de 2
    • Press the optical drive tab to release the drive component.
    • Gently pull and remove the component from the computer.
Conclusión
3 personas más completaron esta guía.
Amber Schindler
Miembro Desde 10/26/16
1,027 Reputación
6 Guías creadas
Equipo
UW Tacoma, Team 1-5, Rose Fall 2016 Miembro de UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 2,388
