Saltar al contenido principal
HP ProBook 4540s Keyboard Replacement
Qué necesitas
  1. HP ProBook 4540s Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Keyboard Replacement, Bottom Door: paso 2, imagen 1 de 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Remove four 6.0 mm Phillips PM2.5x6.0 screws.
  4. HP ProBook 4540s Keyboard Replacement: paso 4, imagen 1 de 1
    • Turn the computer over and position it right-side up in order and open the computer as far as possible.
  5. HP ProBook 4540s Keyboard Replacement: paso 5, imagen 1 de 1
    • Move the keyboard in a downward fashion towards the palm rest.
  6. HP ProBook 4540s Keyboard Replacement: paso 6, imagen 1 de 1
    • Lift the top of the keyboard at an angle and then gently pull it up and away from the palm rest.
    • Only pull the keyboard up enough to release it. The cable beneath the keyboard will still be attached to the system board.
  7. HP ProBook 4540s Keyboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the keyboard cable by lifting the latch at the center of the system board.
    • Completely remove the keyboard.
Conclusión
15 personas más completaron esta guía.
Amber Schindler
Miembro Desde 10/26/16
1,027 Reputación
6 Guías creadas
Equipo
UW Tacoma, Team 1-5, Rose Fall 2016 Miembro de UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Miembros
6 Guías creadas
2 comentarios
Precise and clear guide. Great Work!!!
Mario Mutale - Contestar
Easy to follow and a great help to get the job done. Thanks
d1211109 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 7,101
