Introducción
This guide is on how to replace the touch pad on a HP ProBook 450 G4. The touch pad is the rectangle under the keyboard that acts as a mouse, or a control to the cursor on your screen. You may need to replace your touchpad for a few reasons, such as your touch pad being unresponsive, it being damaged or dented, or your touchpad is picking up movements that you aren't controlling.
Qué necesitas
Flip the laptop over.
Orient the laptop so the two vents on the bottom face upward and are further away from you.
Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
Orient the laptop so the keyboard is facing upwards and towards you.
Insert the spudger in between the edge of the keyboard and the computer frame.
Slide the spudger around the edge of the keyboard until the keyboard is loose.
Gently pull the keyboard away from the body of the laptop.
Flip the laptop back over so it is facing upwards.
Remove the six 6.6 mm screws underneath where the keyboard used to be using a T8 Torx screwdriver.
