Saltar al contenido principal
HP ProBook 450 G4 Display Assembly Replacement
Qué necesitas
  1. HP ProBook 450 G4 Display Assembly Replacement, Back Panel: paso 1, imagen 1 de 2 HP ProBook 450 G4 Display Assembly Replacement, Back Panel: paso 1, imagen 2 de 2
    • Power off your laptop and flip it over so that the bottom faces upward.
    • Use the Phillips #0 screwdriver to remove the screw securing the service door.
    • Use a Jimmy to remove the service door.
  2. HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: paso 2, imagen 1 de 2 HP ProBook 450 G4 Display Assembly Replacement, Display Assembly: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
    • Remove the black 3.2mm screw that secures the hard drive to the left side of the laptop with a Phillips #0 screwdriver.
    • Use the spudger to lift the left side of the hard drive, and remove.
  3. HP ProBook 450 G4 Display Assembly Replacement: paso 3, imagen 1 de 2 HP ProBook 450 G4 Display Assembly Replacement: paso 3, imagen 2 de 2
    • Remove all 6.6 mm T8 Torx screws, including where the hard drive used to be.
  4. HP ProBook 450 G4 Display Assembly Replacement: paso 4, imagen 1 de 2 HP ProBook 450 G4 Display Assembly Replacement: paso 4, imagen 2 de 2
    • Unclip the wires from the Wi-Fi card.
    • Remove the Wi-Fi card.
  5. HP ProBook 450 G4 Display Assembly Replacement: paso 5, imagen 1 de 3 HP ProBook 450 G4 Display Assembly Replacement: paso 5, imagen 2 de 3 HP ProBook 450 G4 Display Assembly Replacement: paso 5, imagen 3 de 3
    • Flip the laptop over, and use a Jimmy to loosen the keypad from the laptop.
    • Use the spudger to unclip the tab.
    • Remove the top case once all tabs are loose.
  6. HP ProBook 450 G4 Display Assembly Replacement: paso 6, imagen 1 de 1
    • Use the spudger to disconnect the black wire.
  7. HP ProBook 450 G4 Display Assembly Replacement: paso 7, imagen 1 de 2 HP ProBook 450 G4 Display Assembly Replacement: paso 7, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws from the hinges.
    • Repeat on both sides.
  8. HP ProBook 450 G4 Display Assembly Replacement: paso 8, imagen 1 de 1
    • Remove and replace the display assembly.
Conclusión
Nat Robinson
Miembro Desde 02/08/24
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 42
