Saltar al contenido principal
HP ProBook 450 G3 RAM Replacement
Qué necesitas
  1. HP ProBook 450 G3 RAM Replacement, RAM: paso 1, imagen 1 de 3 HP ProBook 450 G3 RAM Replacement, RAM: paso 1, imagen 2 de 3 HP ProBook 450 G3 RAM Replacement, RAM: paso 1, imagen 3 de 3
    • The screw is not supposed to come out. It is there to hold the case down.
    • Unscrew the 2.5 mm screw with PH00 screwdriver.
    • Pull the cover off the computer using two hands.
  2. HP ProBook 450 G3 RAM Replacement: paso 2, imagen 1 de 3 HP ProBook 450 G3 RAM Replacement: paso 2, imagen 2 de 3 HP ProBook 450 G3 RAM Replacement: paso 2, imagen 3 de 3
    • Push the bars that hold the RAM in place down. The RAM should pop up.
    • Carefully remove the RAM by pulling it out.
Conclusión
Jingyuan Zhang
Miembro Desde 10/20/17
637 Reputación
5 Guías creadas
Equipo
Un comentario
What kind of RAM is it?
Luigi Provencher - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 4,052
