Introducción
A computer fan is a part that is constantly in use while the computer is on. This can cause it to eventually fail. This guide will show you how to replace your fan in order to extend the life of your laptop.
Qué necesitas
Push the release on the right side of the computer to the center.
Push and hold the release on the left side of the computer towards the center.
Unscrew the 2.5 mm screw with PH00 screwdriver.
Pull the cover off the computer using two hands.
Remove the 2.5 torx screw.
Pivot the spudger between the hard-drive and the optical drive. Push the optical drive away from the center of the computer.
Once the battery, hard drive, and optical drive cover are removed, begin removing all of the screws on the bottom plate of the laptop.
These are Phillips 00 5mm screws.
There are also several Phillips 00 2.5mm screws under the battery, optical drive cover, and hard drive.
8 personas más completaron esta guía.
2 comentarios
The 4 screws in the corners under the black rubber pads are missing in this guide!
