Saltar al contenido principal
HP ProBook 440 G1 Wifi Card Replacement
Qué necesitas
  1. HP ProBook 440 G1 Wifi Card Replacement, Battery: paso 1, imagen 1 de 2 HP ProBook 440 G1 Wifi Card Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Wifi Card Replacement: paso 2, imagen 1 de 2 HP ProBook 440 G1 Wifi Card Replacement: paso 2, imagen 2 de 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Wifi Card Replacement, Backplate: paso 3, imagen 1 de 3 HP ProBook 440 G1 Wifi Card Replacement, Backplate: paso 3, imagen 2 de 3 HP ProBook 440 G1 Wifi Card Replacement, Backplate: paso 3, imagen 3 de 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Wifi Card Replacement: paso 4, imagen 1 de 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Wifi Card Replacement, Wifi Card: paso 5, imagen 1 de 2 HP ProBook 440 G1 Wifi Card Replacement, Wifi Card: paso 5, imagen 2 de 2
    • Locate the Wifi card, found opposite the battery and across from the hard drive.
  6. HP ProBook 440 G1 Wifi Card Replacement: paso 6, imagen 1 de 2 HP ProBook 440 G1 Wifi Card Replacement: paso 6, imagen 2 de 2
    • Remove the wire located near the screws on the wifi card.
  7. HP ProBook 440 G1 Wifi Card Replacement: paso 7, imagen 1 de 2 HP ProBook 440 G1 Wifi Card Replacement: paso 7, imagen 2 de 2
    • Remove the two Phillips #00 screws holding the wifi card in place.
  8. HP ProBook 440 G1 Wifi Card Replacement: paso 8, imagen 1 de 1
    • Remove the wifi card.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 1,578
