Saltar al contenido principal
HP ProBook 440 G1 Keyboard Replacement
Qué necesitas
  1. HP ProBook 440 G1 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 HP ProBook 440 G1 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Keyboard Replacement: paso 2, imagen 1 de 2 HP ProBook 440 G1 Keyboard Replacement: paso 2, imagen 2 de 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Keyboard Replacement, Backplate: paso 3, imagen 1 de 3 HP ProBook 440 G1 Keyboard Replacement, Backplate: paso 3, imagen 2 de 3 HP ProBook 440 G1 Keyboard Replacement, Backplate: paso 3, imagen 3 de 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Keyboard Replacement: paso 4, imagen 1 de 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 2 HP ProBook 440 G1 Keyboard Replacement, Keyboard: paso 5, imagen 2 de 2
    • Locate the two screws on the back of the laptop, holding the keyboard.
    • Remove the two screws using a Phillips #00 screwdriver.
  6. HP ProBook 440 G1 Keyboard Replacement: paso 6, imagen 1 de 1
    • Flip the computer over so as to see the keyboard.
  7. HP ProBook 440 G1 Keyboard Replacement: paso 7, imagen 1 de 2 HP ProBook 440 G1 Keyboard Replacement: paso 7, imagen 2 de 2
    • Place both hands on the keyboard and slide it back.
    • The keyboard will only slide back a small amount.
  8. HP ProBook 440 G1 Keyboard Replacement: paso 8, imagen 1 de 2 HP ProBook 440 G1 Keyboard Replacement: paso 8, imagen 2 de 2
    • Using a plastic opening tool, pull the keyboard up.
  9. HP ProBook 440 G1 Keyboard Replacement: paso 9, imagen 1 de 3 HP ProBook 440 G1 Keyboard Replacement: paso 9, imagen 2 de 3 HP ProBook 440 G1 Keyboard Replacement: paso 9, imagen 3 de 3
    • Locate the connector strip between the keyboard and the laptop.
    • Pull the strip away from the connector until it unplugs.
    • It may take some force to make the strip disconnect.
Conclusión
Una persona más ha completado esta guía.
Un comentario
thanks for that
sir i want original keyboard 440 G1
if u dont mine suggest me
karun kumar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 2,258
