Saltar al contenido principal
HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement
Qué necesitas
  1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: paso 1, imagen 1 de 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 2, imagen 1 de 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 2, imagen 2 de 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: paso 3, imagen 1 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: paso 3, imagen 2 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: paso 3, imagen 3 de 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 4, imagen 1 de 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): paso 5, imagen 1 de 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): paso 5, imagen 2 de 2
    • Locate the hard drive, opposite the battery across from the wireless card.
  6. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 6, imagen 1 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 6, imagen 2 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 6, imagen 3 de 3
    • Remove all four Phillips #00 screws that hold the hard drive in place.
  7. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 7, imagen 1 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 7, imagen 2 de 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 7, imagen 3 de 3
    • Lift up on the outer part of the hard drive.
    • Pull the hard drive out.
  8. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 8, imagen 1 de 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: paso 8, imagen 2 de 2
    • Remove the four Phillips #00 screws holding the HDD in the HDD cover.
    • The HDD should slide out after all screws are removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 24
Todo El Tiempo: 4,419
