Saltar al contenido principal
HP ProBook 4320t Keyboard Replacement Guide
Qué necesitas
  1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: paso 1, imagen 1 de 2 HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: paso 1, imagen 2 de 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Keyboard Replacement Guide, Screws: paso 2, imagen 1 de 2 HP ProBook 4320t Keyboard Replacement Guide, Screws: paso 2, imagen 2 de 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Keyboard Replacement Guide, Flip: paso 3, imagen 1 de 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Keyboard Replacement Guide, Push N Lift: paso 4, imagen 1 de 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Keyboard Replacement Guide, Unscrewing: paso 5, imagen 1 de 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: paso 6, imagen 1 de 2 HP ProBook 4320t Keyboard Replacement Guide, Careful Now: paso 6, imagen 2 de 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Keyboard Replacement Guide, Disconnect Wire: paso 7, imagen 1 de 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Conclusión
Joshua
Miembro Desde 09/23/14
134 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 9-5, Blackwell Fall 2014 Miembro de USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 965
