Saltar al contenido principal
HP Prime Graphing Calculator G8X92A Battery Replacement
Qué necesitas
  1. HP Prime Graphing Calculator G8X92A Battery Replacement, Battery: paso 1, imagen 1 de 2 HP Prime Graphing Calculator G8X92A Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Battery Replacement: paso 2, imagen 1 de 3 HP Prime Graphing Calculator G8X92A Battery Replacement: paso 2, imagen 2 de 3 HP Prime Graphing Calculator G8X92A Battery Replacement: paso 2, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Battery Replacement: paso 3, imagen 1 de 3 HP Prime Graphing Calculator G8X92A Battery Replacement: paso 3, imagen 2 de 3 HP Prime Graphing Calculator G8X92A Battery Replacement: paso 3, imagen 3 de 3
    • Remove the battery.
Conclusión
2 personas más completaron esta guía.
2 comentarios
The link to the battery in the "what you need" section is not correct. The battery is the same as the Samsung Galaxy S3. It has dimensions of approximately 50mmx63mmx5.5mm, with a 4-terminal connector on the top. it is 3.7VDC/7.4Wh. The one that comes with the calculator is "rated" at 2000mAh (whatever that means these days, as battery specs are often works of fiction).
m_a_s - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 22
Ultimos 30 días: 115
Todo El Tiempo: 4,467
