Shut the device off.
  • Shut the device off.
  • Lift the top cover of the scanner.
  • Carefully, pry the plastic frame surrounding the glass away from the printer hood using a plastic prying tool.
  • Pull the frame out.
Agregar Comentario
Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
  • Unscrew the two screws that fasten the frame to the printer hood. Use a T10 screwdriver
Agregar Comentario
  • Pushing the clip behind the cover piece in, pull the cover piece outwards.
Agregar Comentario
  • Remove the two screws on the front of the printer with a T10 screwdriver.
    • The first is inside the power button panel space and the second is across the printer slider.
Agregar Comentario
  • Pull the circuit board from the power button panel space.
  • Unplug the small ribbon cable from the circuit board.
Agregar Comentario
  • Pull the memory card reader's circuit board out of its slot.
  • Detach the rainbow connector from the back of the circuit board.
Agregar Comentario
  • Press the clip directly behind the TouchSmart panel and pull the panel up.
  • Disconnect the ribbon cable from the TouchSmart panel. This detaches the panel from the printer body.
  • Do not hesitate to use force to remove the TouchSmart panel.
Agregar Comentario
  • Grip the printer hood and pull upward.
Agregar Comentario
  • Lift the scanning lid from the lower portion of the printer hood.
Remove torx screw on bottom of assembly in corner near touchsmart screen space.
Jeff - Contestar
  • Leaving the ribbon connected, lift the sliding scanner off the track.
  • Pull the ribbon cable out of the slot on the scanner circuit board.
  • Insert the scanning piece into the rolling track.
Agregar Comentario
Conclusión
To reassemble the sliding scan piece, follow these instructions in reverse order.
Renee Lamb
Miembro Desde 26/09/12
226 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 2-11, Propen Fall 2012 Miembro de Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 Miembros
6 Guías creadas
Where can i buy the scaning piece? Im from Spain.
Bogdan Cosmin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 4
Últimos 30 Días: 5
Todo El Tiempo: 1,218
