1. Unplug the device from any energy sources.
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
    Agregar Comentario
  2. Carefully pull the frame away from the glass.
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
    Agregar Comentario
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
    Agregar Comentario
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
    Agregar Comentario
    • Unscrew the screw inside the power button panel space.
      • Then, unscrew the screw that is across the printer slider.
    Agregar Comentario
  3. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    Agregar Comentario
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    Agregar Comentario
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
    Agregar Comentario
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
    Agregar Comentario
    • Pull the printer hood upward.
    Agregar Comentario
    • With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
    Agregar Comentario
    • With the glass facing upwards, remove the screw holding the glass in place.
    Agregar Comentario
    • Lift the glass up and away from the printer.
    • Handle glass with care.
    • Replace the broken glass piece with the replacement glass
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
garrett hall
Miembro Desde 26/09/12
49 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-11, Propen Fall 2012 Miembro de Cal Poly, Team 2-11, Propen Fall 2012
CPSU-PROPEN-F12S2G11
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 2,471
