Saltar al contenido principal
HP Photosmart c3180 Scanner Bulb Replacement
Qué necesitas
  1. HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: paso 1, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement, Top Panel of HP Photosmart c3180 printer: paso 1, imagen 2 de 2
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. HP Photosmart c3180 Scanner Bulb Replacement: paso 2, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: paso 2, imagen 2 de 2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. HP Photosmart c3180 Scanner Bulb Replacement: paso 3, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: paso 3, imagen 2 de 2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. HP Photosmart c3180 Scanner Bulb Replacement: paso 4, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: paso 4, imagen 2 de 2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. HP Photosmart c3180 Scanner Bulb Replacement: paso 5, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: paso 5, imagen 2 de 2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. HP Photosmart c3180 Scanner Bulb Replacement: paso 6, imagen 1 de 1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. HP Photosmart c3180 Scanner Bulb Replacement: paso 7, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: paso 7, imagen 2 de 2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. HP Photosmart c3180 Scanner Bulb Replacement: paso 8, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: paso 8, imagen 2 de 2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. HP Photosmart c3180 Scanner Bulb Replacement: paso 9, imagen 1 de 1
    • Carefully lift the top panel of the printer away from the printer body.
  10. HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: paso 10, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement, Scanner Bulb: paso 10, imagen 2 de 2
    • Set aside the top panel of the printer.
    • Lift the scanner carriage vertically, being careful not to yank of the cables connecting it to the printer.
  11. HP Photosmart c3180 Scanner Bulb Replacement: paso 11, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: paso 11, imagen 2 de 2
    • Flip the scanner carriage over to expose the connectors on the bottom.
    • Carefully remove the small cable from the connector.
    • Carefully remove the large cable from the connector.
  12. HP Photosmart c3180 Scanner Bulb Replacement: paso 12, imagen 1 de 2 HP Photosmart c3180 Scanner Bulb Replacement: paso 12, imagen 2 de 2
    • Remove the scanner carriage from the scanner tray and flip it upside down.
    • Remove the two T10 12mm Torx screws.
    • Remove the scanner carriage from the scanner bulb.
Conclusión
2 personas más completaron esta guía.
Jim
Miembro Desde 10/06/11
1,590 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 20-30, Maness Fall 2011 Miembro de Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Miembros
25 Guías creadas
Un comentario
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
ddaviddierlam - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 29
Todo El Tiempo: 6,076
