Saltar al contenido principal
HP Photosmart D110a Ink Cartridge Replacement
  1. HP Photosmart D110a Ink Cartridge Replacement, Ink Cartridge: paso 1, imagen 1 de 1
    • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • There are two pieces to the mouth, make sure to pull down both.
  2. HP Photosmart D110a Ink Cartridge Replacement: paso 2, imagen 1 de 2 HP Photosmart D110a Ink Cartridge Replacement: paso 2, imagen 2 de 2
    • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
    • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  3. HP Photosmart D110a Ink Cartridge Replacement: paso 3, imagen 1 de 1
    • Place the new cartridge into the slot and press firmly until it pops into place.
Conclusión
2 personas más completaron esta guía.
Tim Wise
Miembro Desde 04/01/11
173 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 10-38, Forte Spring 2011 Miembro de Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Miembros
10 Guías creadas
2 comentarios
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - Contestar
the HP ink cartridge is 60. Does that make any difference???
April -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 12,216
