Saltar al contenido principal
HP Photosmart C4435 Ink Cartridge Replacement
  1. HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: paso 1, imagen 1 de 2 HP Photosmart C4435 Ink Cartridge Replacement, Ink Cartridge: paso 1, imagen 2 de 2
    • Begin by making sure the printer is connected to a power source and is turned on.
    • The printer is turned on when the power button and screen light up.
    • This allows the cartridges to move to the front of the printer for easy access.
  2. HP Photosmart C4435 Ink Cartridge Replacement: paso 2, imagen 1 de 3 HP Photosmart C4435 Ink Cartridge Replacement: paso 2, imagen 2 de 3 HP Photosmart C4435 Ink Cartridge Replacement: paso 2, imagen 3 de 3
    • Pull the handle at the front of the printer to access the ink cartridges compartment.
    • The cartridges will be on the right side of the printer.
  3. HP Photosmart C4435 Ink Cartridge Replacement: paso 3, imagen 1 de 3 HP Photosmart C4435 Ink Cartridge Replacement: paso 3, imagen 2 de 3 HP Photosmart C4435 Ink Cartridge Replacement: paso 3, imagen 3 de 3
    • Press down on the top of the ink cartridge with little force to release them.
    • The teal cartridge is for colored ink. The black cartridge is for black ink.
  4. HP Photosmart C4435 Ink Cartridge Replacement: paso 4, imagen 1 de 3 HP Photosmart C4435 Ink Cartridge Replacement: paso 4, imagen 2 de 3 HP Photosmart C4435 Ink Cartridge Replacement: paso 4, imagen 3 de 3
    • Remove the protective sticker on your new ink cartridge before using it.
  5. HP Photosmart C4435 Ink Cartridge Replacement: paso 5, imagen 1 de 2 HP Photosmart C4435 Ink Cartridge Replacement: paso 5, imagen 2 de 2
    • Push the new ink cartridge forward into the slot.
    • You will hear and feel the ink cartridge click into place if done correctly.
    • Repeat Steps 4 and 5 for each cartridge that needs to be replaced.
  6. HP Photosmart C4435 Ink Cartridge Replacement: paso 6, imagen 1 de 2 HP Photosmart C4435 Ink Cartridge Replacement: paso 6, imagen 2 de 2
    • Close the ink compartment before using the printer.
Linea de Meta
Kalvin Trac
Miembro Desde 09/10/21
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 295
