Introducción
To remove the hard drive you will need a Phillips PH1 screw driver. Caution not all screws will completely detach.
Qué necesitas
Shut down the computer.
Turn computer upside down so the base is facing upward.
Position the computer so the front is towards you.
Remove two 5mm Phillips #1 screws
Slide the hard drive cover towards the empty battery spot and remove it.
Casi Terminas!
Conclusión
