Saltar al contenido principal
HP Pavillion dm4t-2100 Hard Drive
Qué necesitas
  1. HP Pavillion dm4t-2100 Hard Drive, Battery: paso 1, imagen 1 de 2 HP Pavillion dm4t-2100 Hard Drive, Battery: paso 1, imagen 2 de 2
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Hard Drive: paso 2, imagen 1 de 3 HP Pavillion dm4t-2100 Hard Drive: paso 2, imagen 2 de 3 HP Pavillion dm4t-2100 Hard Drive: paso 2, imagen 3 de 3
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Hard Drive, Hard Drive: paso 3, imagen 1 de 3 HP Pavillion dm4t-2100 Hard Drive, Hard Drive: paso 3, imagen 2 de 3 HP Pavillion dm4t-2100 Hard Drive, Hard Drive: paso 3, imagen 3 de 3
    • Position the computer so the front is towards you.
    • Remove two 5mm Phillips #1 screws
    • Slide the hard drive cover towards the empty battery spot and remove it.
  4. HP Pavillion dm4t-2100 Hard Drive: paso 4, imagen 1 de 3 HP Pavillion dm4t-2100 Hard Drive: paso 4, imagen 2 de 3 HP Pavillion dm4t-2100 Hard Drive: paso 4, imagen 3 de 3
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  5. HP Pavillion dm4t-2100 Hard Drive: paso 5, imagen 1 de 1
    • Disconnect the hard drive cable that is plugged in.
    • Lift the tab on the hard drive to pull it out of the computer.
    • Hard Drive is removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 480
