Saltar al contenido principal
HP Pavillion G7-2235DX Keyboard Replacement
Qué necesitas
  1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Before beginning, make sure the computer is turned off and the charger is disconnected.
    • Flip the computer over, so that the bottom is facing up.
  2. HP Pavillion G7-2235DX Keyboard Replacement: paso 2, imagen 1 de 1
    • To remove the battery, slide the battery switch to the left.
  3. HP Pavillion G7-2235DX Keyboard Replacement: paso 3, imagen 1 de 2 HP Pavillion G7-2235DX Keyboard Replacement: paso 3, imagen 2 de 2
    • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
    • After removing all screws, remove the panel by sliding down.
  4. HP Pavillion G7-2235DX Keyboard Replacement: paso 4, imagen 1 de 1
    • Using a PH screwdriver, remove the screw adjacent to the white labels.
    • There is a keyboard icon next to the screw
  5. HP Pavillion G7-2235DX Keyboard Replacement: paso 5, imagen 1 de 1
    • Flip the laptop over, and open it.
  6. HP Pavillion G7-2235DX Keyboard Replacement: paso 6, imagen 1 de 1
    • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
    • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
  7. HP Pavillion G7-2235DX Keyboard Replacement: paso 7, imagen 1 de 2 HP Pavillion G7-2235DX Keyboard Replacement: paso 7, imagen 2 de 2
    • Using both hands, carefully lift the keyboard off of the laptop.
    • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team 1-7, Leahy Fall 2016 Miembro de USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 82
Todo El Tiempo: 2,626
