Saltar al contenido principal
HP Pavilion zv5000 Keyboard Replacement
Qué necesitas
  1. HP Pavilion zv5000 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Keyboard Replacement: paso 2, imagen 1 de 2 HP Pavilion zv5000 Keyboard Replacement: paso 2, imagen 2 de 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Keyboard Replacement: paso 3, imagen 1 de 2 HP Pavilion zv5000 Keyboard Replacement: paso 3, imagen 2 de 2
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 HP Pavilion zv5000 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
  5. HP Pavilion zv5000 Keyboard Replacement: paso 5, imagen 1 de 1
    • Flip laptop back over and open as far as it can go.
  6. HP Pavilion zv5000 Keyboard Replacement: paso 6, imagen 1 de 1
    • Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
    • If the plastic spudger is not doing the trick, try using the metal spudger careful to not pop any keys out.
  7. HP Pavilion zv5000 Keyboard Replacement: paso 7, imagen 1 de 2 HP Pavilion zv5000 Keyboard Replacement: paso 7, imagen 2 de 2
    • Use hands to completely lift off the strip cover and remove.
  8. HP Pavilion zv5000 Keyboard Replacement: paso 8, imagen 1 de 1
    • Use the Phillips #0 screwdriver again, unscrew all four Phillips PM 2.5X13.0mm screws from the top of the keyboard and set aside.
  9. HP Pavilion zv5000 Keyboard Replacement: paso 9, imagen 1 de 2 HP Pavilion zv5000 Keyboard Replacement: paso 9, imagen 2 de 2
    • Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
    • Do not aggressively pull at the keyboard for risk of ripping the connector cable.
  10. HP Pavilion zv5000 Keyboard Replacement: paso 10, imagen 1 de 2 HP Pavilion zv5000 Keyboard Replacement: paso 10, imagen 2 de 2
    • Gently slide out the connecting cable from the laptop to the keyboard.
    • Do not aggressively pull at the connecting cable.
  11. HP Pavilion zv5000 Keyboard Replacement: paso 11, imagen 1 de 1
    • Completely remove the keyboard from the rest of the laptop.
Conclusión
Eliza Marks
Miembro Desde 10/18/16
649 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 4-6, Catania Fall 2016 Miembro de UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
Miembros de 3
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 910
