Saltar al contenido principal
HP Pavilion ze5000 Screen Replacement
Qué necesitas
  1. HP Pavilion ze5000 Screen Replacement, Screen: paso 1, imagen 1 de 3 HP Pavilion ze5000 Screen Replacement, Screen: paso 1, imagen 2 de 3 HP Pavilion ze5000 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Remove two 5.0 mm Philips #0 screws on the hinge of the device
  2. HP Pavilion ze5000 Screen Replacement: paso 2, imagen 1 de 2 HP Pavilion ze5000 Screen Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
  3. HP Pavilion ze5000 Screen Replacement: paso 3, imagen 1 de 3 HP Pavilion ze5000 Screen Replacement: paso 3, imagen 2 de 3 HP Pavilion ze5000 Screen Replacement: paso 3, imagen 3 de 3
    • Remove the connection between the plastic case and interior of the device
  4. HP Pavilion ze5000 Screen Replacement: paso 4, imagen 1 de 3 HP Pavilion ze5000 Screen Replacement: paso 4, imagen 2 de 3 HP Pavilion ze5000 Screen Replacement: paso 4, imagen 3 de 3
    • Remove the connection from the exposed hinge and interior of the device
  5. HP Pavilion ze5000 Screen Replacement: paso 5, imagen 1 de 2 HP Pavilion ze5000 Screen Replacement: paso 5, imagen 2 de 2
    • Remove the 3.5 mm philips #00 screw on the small circuit board on the hinge
  6. HP Pavilion ze5000 Screen Replacement: paso 6, imagen 1 de 2 HP Pavilion ze5000 Screen Replacement: paso 6, imagen 2 de 2
    • Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
  7. HP Pavilion ze5000 Screen Replacement: paso 7, imagen 1 de 1
    • Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
    • It may be easier to use tweezers for this part
  8. HP Pavilion ze5000 Screen Replacement: paso 8, imagen 1 de 3 HP Pavilion ze5000 Screen Replacement: paso 8, imagen 2 de 3 HP Pavilion ze5000 Screen Replacement: paso 8, imagen 3 de 3
    • Unscrew the six 5.0 mm Philips #0 screws underneath the caps
  9. HP Pavilion ze5000 Screen Replacement: paso 9, imagen 1 de 3 HP Pavilion ze5000 Screen Replacement: paso 9, imagen 2 de 3 HP Pavilion ze5000 Screen Replacement: paso 9, imagen 3 de 3
    • Using a spudger, pry the plastic casing off of the screen.
  10. HP Pavilion ze5000 Screen Replacement: paso 10, imagen 1 de 3 HP Pavilion ze5000 Screen Replacement: paso 10, imagen 2 de 3 HP Pavilion ze5000 Screen Replacement: paso 10, imagen 3 de 3
    • Remove four 5.0 mm Philips #0 screws located in the corners of the screen
    • These screws locations will be close to the screws locations in step 2.
    • During reassembly, make sure you do not confuse the proper screw placements from this step and step 4.
  11. HP Pavilion ze5000 Screen Replacement: paso 11, imagen 1 de 2 HP Pavilion ze5000 Screen Replacement: paso 11, imagen 2 de 2
    • Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
    • There will be two 3.5 mm Philips screws on each side
Conclusión
Eric Beaudry
Miembro Desde 03/06/18
823 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 131
