Introducción
This guide is designed to replace the battery of the device: HP Pavilion ze5000. A replacement of a battery should occur if the laptop stops charging or is dead and will not respond to the device's charger. This guide can be used in case a device user wants to check the quality of the battery or replace the battery with a new battery installation. When completing this guide, ensure that the device is properly faced down with the back of the laptop facing the device user.
  1. Push up on the arrow-shaped switch.
    • Push up on the arrow-shaped switch.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. While still holding the  switch up, remove the battery. While still holding the  switch up, remove the battery.
    • While still holding the switch up, remove the battery.
Conclusión
No reassembly in required once the new battery is in.
Gabrielle
Miembro Desde 19/03/18
97 Reputación
1 Guía escrita
Equipo
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 29
