Saltar al contenido principal
HP Pavilion ze4530US Keyboard Replacement
Qué necesitas
  1. HP Pavilion ze4530US Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Unscrew all screws on the back of the laptop.
    • There should be a total of 22 screws.
  2. HP Pavilion ze4530US Keyboard Replacement: paso 2, imagen 1 de 2 HP Pavilion ze4530US Keyboard Replacement: paso 2, imagen 2 de 2
    • Remove all the protective covers such as the RAM protective cover.
    • Then remove the battery by pushing up on the battery release switch and pull the battery out.
  3. HP Pavilion ze4530US Keyboard Replacement: paso 3, imagen 1 de 1
    • Wedge open the top panel located above the keyboard.
    • This piece will not come off.
    • 5 screws should be visible under the lifted panel. Unscrew all screws attaching the keyboard to the laptop.
  4. HP Pavilion ze4530US Keyboard Replacement: paso 4, imagen 1 de 1
    • Once all the screws are taken out of the top portion of the keyboard, wedge open the keyboard on all sides of the keyboard.
  5. HP Pavilion ze4530US Keyboard Replacement: paso 5, imagen 1 de 1
    • Lift the keyboard and unplug it out of the socket.
  6. HP Pavilion ze4530US Keyboard Replacement: paso 6, imagen 1 de 1
    • You have successfully removed the keyboard.
Conclusión
Sonny Sem
Miembro Desde 10/11/16
356 Reputación
3 Guías creadas
Equipo
Texas Tech, Team 38-5, Bennett Fall 2016 Miembro de Texas Tech, Team 38-5, Bennett Fall 2016
TTU-BENNETT-F16S38G5
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 155
