Saltar al contenido principal
HP Pavilion x360 m3-u103dx Battery Replacement
Qué necesitas
  1. HP Pavilion x360 m3-u103dx Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
  2. HP Pavilion x360 m3-u103dx Battery Replacement: paso 2, imagen 1 de 1
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. HP Pavilion x360 m3-u103dx Battery Replacement: paso 3, imagen 1 de 1
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. HP Pavilion x360 m3-u103dx Battery Replacement: paso 4, imagen 1 de 3 HP Pavilion x360 m3-u103dx Battery Replacement: paso 4, imagen 2 de 3 HP Pavilion x360 m3-u103dx Battery Replacement: paso 4, imagen 3 de 3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  5. HP Pavilion x360 m3-u103dx Battery Replacement: paso 5, imagen 1 de 2 HP Pavilion x360 m3-u103dx Battery Replacement: paso 5, imagen 2 de 2
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  6. HP Pavilion x360 m3-u103dx Battery Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  7. HP Pavilion x360 m3-u103dx Battery Replacement: paso 7, imagen 1 de 2 HP Pavilion x360 m3-u103dx Battery Replacement: paso 7, imagen 2 de 2
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Can i use the laptop even without a battery??
PAPISSS PH - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 53
Todo El Tiempo: 6,766
