Saltar al contenido principal
HP Pavilion x360 m3-u001dx Speakers Replacement
Qué necesitas
  1. HP Pavilion x360 m3-u001dx Speakers Replacement, Keyboard: paso 1, imagen 1 de 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 2, imagen 1 de 2 HP Pavilion x360 m3-u001dx Speakers Replacement: paso 2, imagen 2 de 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 3, imagen 1 de 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 4, imagen 1 de 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 5, imagen 1 de 2 HP Pavilion x360 m3-u001dx Speakers Replacement: paso 5, imagen 2 de 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 6, imagen 1 de 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Heavy-Duty Spudger
    Comprar
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 8, imagen 1 de 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Speakers Replacement, Battery: paso 9, imagen 1 de 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 10, imagen 1 de 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Speakers Replacement, USB Port Shield: paso 11, imagen 1 de 3 HP Pavilion x360 m3-u001dx Speakers Replacement, USB Port Shield: paso 11, imagen 2 de 3 HP Pavilion x360 m3-u001dx Speakers Replacement, USB Port Shield: paso 11, imagen 3 de 3
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
  12. HP Pavilion x360 m3-u001dx Speakers Replacement, System Board (Motherboard): paso 12, imagen 1 de 3 HP Pavilion x360 m3-u001dx Speakers Replacement, System Board (Motherboard): paso 12, imagen 2 de 3 HP Pavilion x360 m3-u001dx Speakers Replacement, System Board (Motherboard): paso 12, imagen 3 de 3
    Heavy-Duty Spudger
    Comprar
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  13. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 13, imagen 1 de 2 HP Pavilion x360 m3-u001dx Speakers Replacement: paso 13, imagen 2 de 2
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  14. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 14, imagen 1 de 2 HP Pavilion x360 m3-u001dx Speakers Replacement: paso 14, imagen 2 de 2
    • Pull the clipped cables from system board (motherboard).
  15. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 15, imagen 1 de 3 HP Pavilion x360 m3-u001dx Speakers Replacement: paso 15, imagen 2 de 3 HP Pavilion x360 m3-u001dx Speakers Replacement: paso 15, imagen 3 de 3
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  16. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 16, imagen 1 de 1
    • Carefully lift the front side of the system board (motherboard).
  17. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 17, imagen 1 de 1
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  18. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 18, imagen 1 de 1
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
  19. HP Pavilion x360 m3-u001dx Speakers Replacement, Speakers: paso 19, imagen 1 de 1
    • Remove the cable from its routing path.
  20. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 20, imagen 1 de 2 HP Pavilion x360 m3-u001dx Speakers Replacement: paso 20, imagen 2 de 2
    • Remove the 2 Phillips 3.0 x 5.6 mm screws.
  21. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 21, imagen 1 de 1
    • Carefully peel back the foil as necessary to free the speaker cable from the base of the laptop.
  22. HP Pavilion x360 m3-u001dx Speakers Replacement: paso 22, imagen 1 de 1
    • Lift the speakers away from the base of the laptop.
Conclusión
Follow these instructions in reverse order to reassemble your device.
Subhleen
Miembro Desde 02/01/17
1,268 Reputación
5 Guías creadas
Equipo
UW Tacoma, Team 1-6, Rose Winter 2017 Miembro de UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 562
