Saltar al contenido principal
HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement
Qué necesitas
  1. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Keyboard: paso 1, imagen 1 de 1
    • Power off your device and disconnect all external devices connected to the laptop.
    • Working on your device while it is powered on may cause damage to the laptop or result in electric shock.
  2. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 2, imagen 1 de 1
    • Flip the laptop over and remove the rubber foot with a Metal Spudger.
  3. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 3, imagen 1 de 1
    • Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws
    • 7 Phillips 2.0 x 5.0 mm screws
    • Keep the different sized screws separate for future replacement.
  4. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 4, imagen 1 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 4, imagen 2 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 4, imagen 3 de 3
    • Flip the laptop back over and open it; the keyboard should be facing upwards.
    • Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
    • The keyboard is connected to the motherboard with cable ribbons, so be very gentle and careful when lifting the keyboard.
  5. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 5, imagen 1 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 5, imagen 2 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Heavy-Duty Spudger
    Comprar
    • Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
    • Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  6. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 6, imagen 1 de 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 6, imagen 2 de 2
    • Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
    • Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
  7. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 7, imagen 1 de 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 7, imagen 2 de 2
    • After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
  8. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: paso 8, imagen 1 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: paso 8, imagen 2 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: paso 8, imagen 3 de 3
    • Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
    • 3 Phillips 2.0 x 4.6 mm screws
  9. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 9, imagen 1 de 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 9, imagen 2 de 2
    • Holding the lower right corner, gently lift up the battery to disconnect it from the motherboard.
  10. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, System Board (Motherboard): paso 10, imagen 1 de 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, System Board (Motherboard): paso 10, imagen 2 de 2
    • Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
    • 8 Phillips 2.0 x 4.7 mm screws.
  11. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 11, imagen 1 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 11, imagen 2 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 11, imagen 3 de 3
    • Disconnect the 3 bundle cable connectors by gently gripping the cable wires and pulling outwards.
    • Be sure to grip each of the cables equally so no single cable is overly strained.
  12. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 12, imagen 1 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 12, imagen 2 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 12, imagen 3 de 3
    Heavy-Duty Spudger
    Comprar
    • Disconnect the 2 cable ribbons with the Heavy-Duty Spudger.
    • Use the purple plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  13. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 13, imagen 1 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 13, imagen 2 de 3 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: paso 13, imagen 3 de 3
    • Gently lift up the motherboard to disconnect it from the computer.
Conclusión
Un comentario
where can I get this mother board from
Kevin Juma - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 22
Todo El Tiempo: 2,237
