Introducción
If your speakers are malfunctioning (no sound or distorted sound), the speakers may need to be replaced. To replace the speakers, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
Qué necesitas
Power off your device and disconnect all external devices connected to the laptop.
Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
3 Phillips 2.0 x 4.6 mm screws
Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
8 Phillips 2.0 x 4.7 mm screws.
Disconnect the bundle cable connector by gently gripping the cable wires and pulling outwards.
Remove the screws from the sound piece with a Phillips 00 Screwdriver.
2 Phillips 2.4 x 5.7 mm screws
