Introducción
If power drains quickly for your battery or your battery will not charge, you may need to replace your battery. To replace the battery, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
Qué necesitas
Power off your device and disconnect all external devices connected to the laptop.
Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
3 Phillips 2.0 x 4.6 mm screws
