Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement
Qué necesitas
  1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): paso 1, imagen 1 de 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): paso 1, imagen 2 de 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): paso 1, imagen 3 de 3
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 2, imagen 1 de 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 2, imagen 2 de 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 2, imagen 3 de 3
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  3. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 3, imagen 1 de 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 3, imagen 2 de 3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 3, imagen 3 de 3
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 4, imagen 1 de 2 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 4, imagen 2 de 2
    • Pinch and lift the small WLAN plate.
  5. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 5, imagen 1 de 1
    • Use PH1 to remove the 2.5mm holding screw.
  6. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 6, imagen 1 de 2 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: paso 6, imagen 2 de 2
    • Pull the SSD out and up, away from the connector.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 876
